Trunk 88
icarus1963
Brantford, Ontario
Trying to monitor a system using my SDR and Trunk 88, and when opening I receive a "Cant load libusb-1.0 dll" error.
I think I have The Trunk88.CTL file configured properly. Any suggestions.
Thanks,
Andy
ScubaJungle
West Central Florida
If im not mistaken, that program isnt even supported anymore, so you may have trouble finding help. Id suggest trying Unitrunker V2, SDRTrunk, or DSDPlus
Forts
Ontario, Canada
Depends what you are trying to monitor.... For a smartzone system T88 is fantastic.
What version are you running? I can pluck the dll from my folder and send it to you if you like.
icarus1963
Brantford, Ontario
I am trying to monitor Bell Fleetnet Zone 1. The version I have is 4.89W, and I would love it if you could do that.
Thanks,
Andy
slicerwizard
Toronto, Ontario
Thanks,
Andy
From the SDR Guide.txt file:
Required DLLs
TRUNK88 uses rtlsdr.dll and libusb-1.0.dll to interface with DVB-T dongles;
these DLLs must be copied to your TRUNK88 folder.
Those two DLLs use msvcr100.dll, which is already present on most Windows
systems; if you see an error message that refers to this DLL, you should
add a copy of msvcr100.dll to your TRUNK88 folder.
You can find these DLLs in http://home.ica.net/~phoenix/wap/TRUNK88/SDR.zip
You're mistaken.
CanesFan95
Analog already is interoperable.
FL
My county is still on EDACS and boy have I always wished Trunk88 did EDACS. The old windows etrunk only seemed to work on older operating systems which is too bad.
