I cannot figure out why Trunker will not run on my new laptop. Any help would be appreciated.
Here's the lowdown on everything:
- Windows XP Operating System
- Optocom With Bit Banger Option
- Latest Version of Trunker
I've run SLICER and know that the Optocom puts out a nice signal on pin DSR and is INVERTED. Plenty of interupts for TRUNKER.
Here's my TRACKENV2.TXT FILE:
TRACKSLICERPORT=COM1
TRACKSLICERPIN=DSR
TRACKSLICERMODE=INVERT
Here's my batch file to get Trunker running:
SET TRACKENV=C:\TRUNKER\TRACKENV2.TXT
TRUNKER.EXE
It takes off, displays the screen, and in about 5 seconds I get the red wantDSR??? message. I go to manually configure the pin and mode with no luck.
The signal I'm trying to listen to is about 10 miles away across open country - no issues with reception.
I've tried running it with a desktop shortcut and via the Command Prompt window, but no luck.
I can successfully run LTRTRUNK using by BC780 on the same computer.
Any ideas? Is XP too complicated for TRUNKER? Might there me a conflicting application that's trying to run the COM1 port?
Any help would be greatly appreciated!!!
TRACKSLICERPIN=DSR
TRUNKER.EXE
