ccfire
What's the difference between an incident channel and an event channel
CCFIRE, please do not confuse the responses above to clarify issues specifically within your county's radio template.
Your incident channels 1-3 are supposed to be utilized when there is a multi-unit response (not POVs) to the same incident or multi agency response that requires all to talk to each other. In other words. If it is not a routine medical, then you should be using an incident channel.
Event 1-2 would be used if your Dept is officially present/working at any public event (such as the county fair) and your units are involved in medical/first aid stand by or fire watch.
Just because you volunteer in a disorganized county, doesn't mean you can not be professional. Even if the others around you, do not follow suit![]()
I've reread yours three times now. What exactly, in your post, conflicts with mine?
Lastly,
This is ill advised.
Respectfully, use the talk groups the way your department has them set up.
