TRX-1 setting LED to channels?
Hogwire56
Scan Maine
Portland
I set up my frequencies with solid color LED in EZ Scan software to my scanner. Or so I thought I did. Checked the box then set and nothing. Any help would be appreciated. Thanks
Swipesy
Northern Ohio
Your EZScan setup should look like attached. Be sure LED Mode is set to "ON"
Swipesy
Northern Ohio
You did load EZScan up to the scanner right? Also you used the dropdown menu for color choices? There are no other settings for the LED that I am aware of.
Swipesy
Northern Ohio
If it still does not work you could try this. Program into your Conventional frequencies your local NOAA frequency and assign a LED color to it. Then load to scanner and run the weather channel and see if your LED lights up. If not you may have a Firmware issue and need to reinstall to see if it fixes the LED
gmclam
Fair Oaks, CA
In EZ Scan: page General Settings. On the right there is a box for "Alert Settings". The Mode pull-down has to be set to either Both or Visual for the LED to illuminate.
Hogwire56
Scan Maine
Portland
yes i checked that. think my sd card may be corrupted or ez scan is.
HavenBTS
Banned by a Super Duper Moderator
Banned
yes It was operator error. After watching youtube videos on EZ Scan it appears i missed a step.
I'm happy you figured it out as I know how frustrating it is when you can't figure out what is wrong.
