TRX-1 UK Bandplan?
Neutrino222
Hi.
I'm looking for a log of the Bandplan changes for the TRX-1 in the UK - any changes performed in the step size allocation is particularly interesting to me. Does such a log exist?
Ubbe
Stockholm, Sweden
I don't know if Whistler has one up to date but it used to look like this:
25,000000 26,960000 10 FM
26,965000 27,405000 10 FM
27,601250 27,991250 10 FM
29,510000 29,700000 5 FM
29,710000 47,000000 10 FM
47,000000 50,000000 5 FM
50,000000 52,000000 10 FM
52,000000 74,987500 12,5 FM
75,000000 88,000000 12,5 FM
108,000000 136,991600 8,33 AM
137,000000 137,995000 5 FM
138,000000 197,000000 6,25 FM
197,006250 219,993750 6,25 FM
220,000000 224,995000 5 FM
225,000000 399,987500 12,5 AM
400,000000 512,000000 6,25 FM
/Ubbe
Ubbe
Stockholm, Sweden
Whistler where gathering info from local people from each country they wanted to support, to sell more E models. This is from a excel document with the info they had at that time. It might have been corrected after that. I know I changed a lot for Sweden depending of what could and what could not be done according to Whistler.
  • Sweden_091519_d.zip
Whistler_Support
Whistler Representative
Bentonville, Arkansas
Attached are the bandplans for CPU 7.2
Shortly there will be a new CPU release 7.3 that will include some updates to the Netherlands bandplan plus 3 new country bandplans.
  • TRX1E2E_03B22_Addendum_1.pdf
Neutrino222
Thanks. Since the Steps cannot be changed, is it possible to load a new Bandplan from a V-folder?
Ubbe
Stockholm, Sweden
Thanks. Since the Steps cannot be changed, is it possible to load a new Bandplan from V-folder?
Bandplans are set fixed in firmware are not part of V-folders which are only configurations. That's why Whistler needs to have people send them corrections and new info to add more country specific bandplans.
/Ubbe
Neutrino222
/Ubbe
Thanks, Ubbe. There is a configuration in the Global Settings where the Bandplan can be changed, so I thought this could be included as part of a v-folder parameter. Never mind.
Ubbe
Stockholm, Sweden
You thought correctly. As the selection of a bandplan are part of the configuration then it will be stored to a V-folder. But the actual data for the bandplan, and the special service scan frequencies and other things in the E model that doesn't exist in the US model, are part of the firmware.
/Ubbe
