no voices on p25 local sheriff talk group it flashes a t when scanning the tower but when it stops on the local sheriff id it flashes an s then no voices.i have talked with whistler by email with nothing working.can hear analog channels fine.
I double checked the file and see nothing wrong with the programming. The only other possibilities are that the control channel and alternate frequencies listed in the database are incorrect, your squelch is too high, or the talkgroups are encrypted. Is there anyone local who can verify that the control channel and alternates frequency information for Clay County on the MSWIN system is correct and that the talkgroups are not encrypted?okay i gave the file a try didnt work.heard traffic on the analog but still the same key up with there display but s flashing and no sound.thanks for yalls help im going to try a few more things and if that dont work im going to send it back to whistler
Try using headphones or an earpiece. You could have dirty contacts on the headphone jack muting the internal speaker.yes i hear them fine on unidens so not encrypted but this morning im having sound issues faintly key beep and faintly hear the wx stations and i tried external speaker so i guess off to whistler thanks for the help
yes sirIs your earpiece plugged into the front headphone jack?
i have tried that but i tried again still nothing barely any sound on my local analog pd with it wide openThe rotary knob can be set to default for volume or squelch. Press in on the knob and see if you can adjust the volume.
i got it december 2020How old is the scanner? It sounds like you will need to send it in for repair.
