Two Antennas Distance
Brales60
Punta Gorda, Fl
So, my new SDS 200 is the ****. So much better than the 996P2. I'm currently running a Omni X, but was thinking about putting up my Sirrio discone to play next to it. I'll get a small jump cable to go back and forth like the Omni has. My main question, how far away from each other should these be? If any.
mass-man
trying to retire...
Parker Co., TX
as it’s receive only a few ft would be good! On top of each other by 3 ft or so would be ideal.,,
ka3aaa
middletown, pa.
you only need to separate antennas when you transmit with them, rx has no set distances to worry about.
Ubbe
Stockholm, Sweden
The Omni-X are sensitive to nearby metal objects as any antenna, the discone type only its top crown.
You can see here what a big metal object can do to the antennas gain and direction pattern:
A 1/2 wave at 150MHz are 1 meter or 3ft.
/Ubbe
