Two Questions
NewSDScanner
San Diego
1. I have a Wouxun KG-UVD1P. On certain repeater frequencies, it can't seem to tune to the exact numbers. For example, a local directory specifies that the repeater is on 446.140 but my radio skips up to 446.150 when I type in 446.140. There is no way for me to get it to stay on 446.140. Also, it has done this with a couple other frequencies. For example, 441.130 goes up to 441.137 and stuff like this. What does this mean?
2. I live in San Diego County but I seem to be getting some LA county ham repeaters loud and clear. In general, if I hear a repeater loud and clear, does that mean that the repeater should hear me loud and clear or at least half-way decently? Basically what I'm asking is if my radio receives well, does that generally mean it will transmit well to a given repeater? Thanks.
nd5y
Wichita Falls, TX
1. Your tuning step is wrong. I think in CA the 440-450 band is 20 kHz spaced repeater channels. Push [MENU] [1] and set STEP to 5.00K or 10.00K and you should be able to enter the correct frequency.
2. Nornally if a repeater is full scale and full quieting you should be able to work it with a hand held but there are too many variables. It may not hear you at all even though you can hear it well.
