UASD Bug - MP25 system becoming MOT2
wm8s
Houston, TX
Every once in a while, when I save my WV Interoperability system's .USD file in UASD, UASD changes the system type from MP25 to (I think) MOT2 and dumps all of the sites. I've learned the hard way to keep a backup, and when this happens, I just manually pull the MP25 command and all of the sites back into the USD file. Has anyone else experienced this? It's not likely operator error, since changing the type of an existing system is not allowed from UASD. Thanks.
...R
BCD996T_OLC.exe Ver.1.0.12.0
BCD996T_UASD.exe Ver.1.0.12.0
BCD996T_Viewer.exe Ver.1.0.12.0
BCD996T_Writer.exe Ver.1.0.12.0
UASD_cfg_edit.exe Ver.1.0.12.0
UASD_loc_edit.exe Ver.1.0.12.0
UASD_sys_edit.exe Ver.1.0.12.0
Location.dll Ver.1.0.12.0
About.dll Ver.1.0.12.0
dougjgray
Englewood CO
I have lost my sites before however, I was doing copy and paste from this site and I think there where some characters the scanner didnt like and didnt save the system properly on the scanner and when I loaded back , from the scanner the system sites where gone unfortuantly I learned to backup. It would be nice if the software would check and strip out bad data before it sends it to the scanner or at least warn you, its happened 2 or 3 times but after the 1st I had a backup and I make sure it uploaded to the scanner properly after I write to the scanner, thats where my problem seemed to happen. My experience may or may not be the same as yours
