Ubc 996t
N4DXX
In the pines where the sun never shines
Has this europian model been released?A friend of mine ordered a 996t from HRO i think he said and his 996 will program all of 800mhz no gaps is this a glitch or what?I told him he was seeing things until i programmed it myself can't say it picked up any signals as i wasn't there long enough to test that part but i do know it exepted the full freq range into memory..Is it possible that a govorment version was shipped out by mistake?Or something wrong with the scanner should he send it back?Not that it would be any benifit just think it's very strange i am gonna see if he will lend it to me tomm for a bit just to see if everything functions as it should as he is new to scanning and i am very interested in this scanner to see whats up with it..Upman can you answer this were there any govmnt models released?With full band coverage?
N4DXX
Update!!Well i have called up my friend he came over with the scanner..I have the arc programming software and i was gonna load it up for him and now after i programmed it with my pc it will now give the error messege when programming the 880 mhz range.and before we uploaded it programming it manualy it would exept this range..scanner seems to work fine just can't understand why this scanner done that... tonite was the first time it was programed with a pc...I have not a clue...you can delete this post if ya want...pointless now i suppose
Air490
Tamworth, NSW, Australia
The UBCD996T is the Australian and New Zealand model. There has been no indication it will be released in Europe. The newest official Euro scanner is the UBC785XLT.
mike_s104
Berkeley Co. WV/ Loudoun Co. VA
other then the 800MHz range, is there anything else different about it? what software did you use?
Hiryzer
Lake grove, NY
I have a question regarding the difference between the UBCD996T and the BCD996T. I am buying a new 996T to go along with my BCD396T which works great. If I could purchase either the UBCD996T or the BCD996T for the same amount of money, which one should I lean to? Some of the scanners that I have are UBC and I have no trouble with them at all.
Thank you for any help ?
Shawn
Hiryzer@optonline.net
