UHF Odd Frequency (SF - Santa Rosa Area)
kg6nlw
Railroad & Ham Radio Extrodinare
Sonoma Co., California
I got a weird one...I stumbled across what sounds like a tow company on 451.625 Mhz, no tone of any sort, definitely analog as a much OLDER Bearcat scanner first heard it.
When searching the RRDB and the FCC ULS, nothing hits locally for that frequency that would indicate a tow company. The "closest" thing is Marin Municipal Water District, DEFINITELY NOT THAT!
Anyone else in the Santa Rosa area able to hear this? It's LOUD in Cloverdale!
Regards,
-Frank C.
kg6nlw
Not sure if LTR would be analog like this, IIRC it has a bit of digital to it being trunked, but that's about the closest I'd be able to hear is Geyser Peak.
I'll wait for others to chime in as well.
Regards,
-Frank C.
KevinC
Other
Super Moderator
Home
Regards,
-Frank C.
LTR is analog and it won't show any info on Uniden scanners. On most GRE/Whistler models it will show the LTR channel info.
scannernerd55
Don't know if the newer Uniden's do it or not, but I know on older models if you created a 'quick search' range with the 'control channel only' function on (though LTR does not technically have a control channel), some LTR info would show up if there was activity on a frequency. So depending which scanner you have, you can try that.
kg6nlw
Heard it on an older Bearcat earlier, I then switched to the RadioShack/GRE scanner with no further data...
Regards,
-Frank C.
pfdradio
Briar Park
I wonder if you are receiving an image, if you hear it with a Bearcat and the GRE/RadioShack. No PL I'm inclined to agree with it being LTR.
What model Bearcat are you using.
kg6nlw
It first came up on a BC350A. I then put my GRE/RadioShack into search mode around the same frequency range.
Regards,
-Frank C.
ramal121
Lots and lots of watts
Calif Whine Country
This is the old analog LTR on Geyser Peak which is a separate system than the IDAS system. I cannot speak for the validity of the license for that location but my customer information shows this as an active channel.
kg6nlw
Likely Site 12, has had additional frequencies added to it
Just a wild wild guess
That might be plausible.
Wouldn't LTR show up as TG: xxxx though on the GRE scanner like other systems do...?
Either way, ALL I hear is tow truck traffic on it.
Regards,
-Frank C.
mikegilbert
MHz so good
Los Angeles
Do you have a good pair of headphones or an external speaker with decent bass response?
If so, hook them up to the scanner and listen for a low warble during transmissions. The low warble is the LTR signaling data.
kg6nlw
I do not. Oh well! I'll just chalk it up as the LTR system with only a tow company being heard!
Regards,
-Frank C.
