Unable to Monitor EPD
jimmnn
Colorado
rkdkpenglewood said:
Umm ok good suggestion??.........I think what you just posted, was the same reason I left my first post...... but I could be wrong (post#58 unable to hear Englewood) Littleton I can monitor (conections in LPD), just a bit boring for the most....
1. You mention a pro-2052 is your radio that will monitor the Denver and Lakewood analog Edacs trunked systems just fine but not the state of colorado DTRS.
2. Check the database here on RR http://www.radioreference.com/modules.php?name=TRSDB&sid=329 and see that both Littleton PD and Englewood PD operate on the states DTRS system so to monitor them you would need a p96 digital trunked scanner such as the Pro-96, Pro-2096 or BC-396T.
3. I work in Englewood so monitor them on a daily basis and they are still doing some simucasting on VHF (154.160 & 155.730) so I would keep those programmed in your radio.
Good luck
Jim<
