Uncation G5 Amplified charger
Synchro39
Montreal Quebec
just get that and i am not really impress by i don't know if it's a defective unit but when i put my G5 on this base even with a better signal the communication cut's out and you can't follow a conversation at all
i also get a weird beep sound but not always i don't know why but when i listen to my G5 without the base i never get this beeping sound and when on the base sometime i get this beep and sometime not
WeBeCinYa
NC
Mine does this as well. It’s like a chirp and the microphone light comes on. I gave up listening to mine in the cradle between that noise and the overall sound from that speaker.
RBMTS
I'm wondering if the two of you have the "alert" on for that talkgroup and that's why it's beeping. On tab 4 in the PPS for the "Group ID Setting", make sure you have "none" listed for the alert tone for the specific TG setting.
WeBeCinYa
NC
This light...
RBMTS
That's the indicator for an alarm - i.e: an alert occurance. Again, I'm guessing you might have an alert tied to a talkgroup. If you can zip and upload your PPS codeplug, we'll take a look.
RBMTS
Make sure the "Alert Tone" is showing NONE if what you are describing is happening on a trunking talk group.
81135
x9TOM27
SW Ohio
For what its worth,
That particular light comes on every time my G5 receives a signal and I hear no beeps, only the amplified voice(s) of the radio traffic...
CFP387
Rowan County, NC
When sitting in the amplified charger, neither my G4 or G5's will alert on a QCII tone. The pager will go silent when it should be alerting and then open back up and receive the voice traffic. When they are off the amplified charger, and / or charging by USB, they will activate as normal.
WeBeCinYa
NC
I have no alerts set. Every time I have a transmission, the yellow horn light or alert light comes on. When the transmission ends, the light stays for a few seconds, then cuts off and when it cuts off, it makes a chirp noise. It’s pretty annoying.
kruser
Well Known Member
W St Louis Cnty, MO
I agree that you should zip up and post a copy of your working pps codeplug here so someone without this issue can compare and see what may be different.
Also, what version is your PPS software, what firmware level is your G5 at, do you have the DMR option installed on the G5?
WeBeCinYa
NC
I have no idea how to zip up a copy of the codeplug. But the version of PPS is the latest, and I updated my firmware a couple weeks ago. No DMR option.
Synchro39
Montreal Quebec
I change all my alert to none and now I don’t have the beeping sound but still not working good when I scan multiple frequency but it’s ok if I don’t scan and leave it on only one frequency
