yeah don't use a Motorola antenna, very very bad, the pin can be fixed but you have to be really careful
That appears to be a Motorola stubby antenna, so refer to post #41. The problem is not with the rubber skirt that has been trimmed (others have done the same). The problem is with the design of the SMA connector itself. (Look at photos of the actual SMA connection on both the OEM and Motorola antennas to see the difference.) There's anecdotal evidence that the Motorola antennas can pull the pin out of the Unication antenna connection. Others report that their OEM Unication stubby no longer works after using the Motorola antenna. I'd steer clear! If you want to experiment with other antennas, I'd opt for an SMA to BNC adapter designed for the Baofeng radios. The SMA connection has the required recess as does the Unication stubby does. Using the BNC adapter allows you to try any BNC-based antenna you wish without potentially damaging the Uncation antenna connection.Has anyone tried one of these yet?
Looks like a knockoff of the Motorola stubby.Has anyone tried one of these yet?
UNICATION G4 G5 ULTIMATE 700 / 800 MHz P25 HD DIGITAL STUBBY ANTENNA PAGER BEST | eBay
We modified by trimming the bottom of these antennas so they fit properly on the Unication G4/G5 Pagers. Base of Antenna has been modified by trimming to allow proper fit on pager. PAGER IS NOT INCLUDED - MODIFIED ANTENNA ONLY!!www.ebay.com
Your comment doesn't change what it looks like.If you read the description, you'll see that it's a E/M Wave antenna intended for Motorola use, with the rubber manually trimmed to "fit" a Gx Pager. I'd still be skeptical around risk of connector damage.
Okay, I am just throwing this out here. I am absolutely not looking for an argument. I am just wondering if there is any information out there, especially from Motorola or Unication, that verifies that either one of them is using a non-standard SMA connector.
Shooting from the hip, l doubt that the Unication SMA connector is non-standard, but perhaps the Motorola SMA is. However, if that is the case, wouldn't/shouldn't they have some sort of disclaimer saying something along the lines of "...this antenna is ONLY for Motorola radios"?
Now, don't get me wrong, I am not doubting that some people may have had problems with their Unications and antennas. What I am wondering, though, is could it be that it was caused by something else? For example, a defective connector or someone tightening it down too much?
Just looking at the Unication SMA vs a Motorola SMA the major difference that I see is that the Unication SMA has more threads which is why the center portion of the SMA is recessed back farther than on a Motorola SMA. Other than that difference they appear nearly identical.If you compare the two connectors, it's very obvious that they are significantly different in the area the mates with the pin. I've posted a side-by-side photo before. I can probably dig it up if you haven't seen it.
The great thing about standards is there's so many to choose from!I've looked around a bit (Google), but haven't been able to find a good SMA specification.
...Honestly, I don't see how this would a problem unless you were constantly swapping out the antenna...
From what I am seeing, there is a standard. There are both SMA and RP-SMA, which refers to Reverse Polarity SMA. Could someone have used a SMA with a RP-SMA?
How much performance gain over the OEM stubby did you achieve? How much trimming is necessary and how did you perform this "operation"? (Sorry for all the questions!I use the Kenwood KRA-32K (700-800mhz) on my G5.
Although it seems counter-intuitive, I have not found a Motorola stubby antenna (tried several) that can beat the OEM antenna receiving ability. To get better reception, I have had to use a gain antenna. The ones I have found that don't damage or push in the pin are certain model Kenwood gain antennas. They have the same recess as the OEM antenna, however, they do need the rubber skirt trimmed like the Moto antennas. I use the Kenwood KRA-32K (700-800mhz) on my G5. And the Kenwood KRA-27 (440-490mhz) on my G3 UHF. If you decide to purchase a Kenwood, do so from a reputable dealer, there are a lot of knock offs out there.
I have found all the Moto antennas will push the pin lower, and even had one take out the pin when removed. If you put a Moto antenna on and leave it on, it is not a problem. But if you regularly change antennas, the pin will be lowered to a point that the OEM antenna will not make a good connection.
The KRA-32K gets me one or two additional bars over the blue band OEM. There is a city about 30 miles away whose system I cannot receive inside my house with the blue OEM, but Kenwood gives me a consistent 1 or 2 bars. Just requires trimming about 1/4 inch with an exacto knife or razor blade, so the rubber is flush with the metal. I found it to be a fairly easy task.How much performance gain over the OEM stubby did you achieve? How much trimming is necessary and how did you perform this "operation"? (Sorry for all the questions!) Thanks.
