Uniden 996P2
JimmyMac
Connecticut
Good evening all.
I am currently using a Uniden 996p2 in my vehicle. For some reason, recently I haven’t been picking up any CSP radio traffic. Up until a few months ago, I was hearing the CSP as well as DEEP. I am located on the CT shoreline. Any guidance would be greatly appreciated.
CT
I monitor both agencies. Nothing has changed.
I also use a 996P2.
I haven't noticed any problems so I would check your antenna connections and your programming.
Reload your programming file?
Good luck!
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Though it may not be a factor for some posters here while monitoring CLMRN, you may be experiencing a well documented phenominon known as simulcast distortion. The only scanners designed to cope with its effects are the Uniden SDS100 & 200 but there are other workarounds mentioned in the wiki I linked you can try, they may or may not work for you depending on your location relative to two or more simulcasting towers
sefrischling
Public Information Officer
New London, CT
Check your radio settings and antenna. I use two 996P2 radios, along with the Unication G5 and other radios, no issues at all monitoring CLMRN. I float between Troop E, F, K, C, D no issues, and listen to DEEP Marine and East every day.
Dan6071
Groton, CT
I have a Whistler I use just for State and Groton Town PD and it works great I also have a bcd 536 and 996p2 with no issues
JimmyMac
Connecticut
If you don’t mind me asking , what type of antenna and what “settings” should I check and what should they be set at ?.
Thanks in advance!
sefrischling
New London, CT
Check your squelch, I keep mine at 5 I believe. I use a Tram VHF 1/4 wave to monitor 33mhz, VHF, UHF, 7/800mhz with the 996P2.
n1chu
Farmington, Connecticut
I have a all band antenna craft base and a austin spectra multi band mobile antenna that works great
The Austin Spectra multi-band mobile antenna has been out-of-stock for quite a while… I have one I’ve been running for better than ten years without issue (back when the price was around $100) but thought I’d put a new one on my new 2021 vehicle, just as a preemptive strike against my current one dying from old age. But Scanner Master is out-of-stock and last time I checked they didn’t know when they would be getting more.
MOTORHEAD27
ESSEX
I bought 4 element yagi antenna 2 years ago. I point it at the site I want it works great.
sefrischling
New London, CT
The normal squelch setting for the BCD996P2 is 2. If set at 5, you will be missing a lot of traffic with lower signal strength.
At anything under 5 there are a number of local VHF and LowBand channels that lock up constantly. I have been using them on a 5 where I live for 10+ years with the 996XT without any issues, as channels constantly locking up the radios really makes you miss traffic, while driving you nuts.
cg
Connecticut
If not hearing the system when mobile is constant, I would say programming. Could be as simple as a locked out control channel. If you get traffic sometimes and then sometimes not, I would look toward interference including simulcast distortion. I believe there was a new tower going up toward the shoreline but not sure. The new Hartland tower is delayed due to supply chain issues.
