have been unable to figure out how to add Wayne NJ PD & FD frequencies into this radio. It has an APCO 25 card also. Wayne uses APCO 25 Phase 1 with one control channel. What am I doing wrong?
I think the previous posters have given you the solution regarding the step size issue.
Regarding the Wayne Township trunked system, I'd change a few things:
1. On the 796D, I don't believe you can use single control channel only for a UHF system like most of the newer model scanners. You'll need to input all the freqs as letarotor suggested.
2. Then you need to input a band plan with the base freq, step and offset channel--see how my system is set up below as an example--yours will most certainly be different. Sometimes that info is included in the RR download, but sometimes it may not be there. I'd suggest checking with someone local--there may be someone in your area that has this info, which would save you lots of time.
3. I'd also check to be certain that you have selected the correct trunking type--you should be using Motorola Type 2 - UHF (also shown in the figure above.) Forget the fact that it's not a Moto system, what matters is that you select the type 2 and the correct band--UHF.
FYI, the software I reference above is Butel ARC250--it's what I bought back in 2003/2004 when I got the scanners, Butel does let you download and try the software before you buy, in case you want to replicate what I've shown you. Another great piece of software is ProScan--it'll program most any Uniden scanner, including the BC796D.
Good luck, I hope this helps.
