UNIDEN BC796D NEBRASKA SRS CUSTOM TABLES
KC0CCB
Edgemont, South Dakota
i have a uniden bc796d that im wanting to program for Nebraska SRS.. I live near Edgemont and can hear the Harrison site up here..
what are the custom tables for the 796d by chance ??
ORION_NE
Onawa, IA
You don't need custom tables. Just enter the control channels and the scanner will download the info from the control channel
tvengr
Well Known Member
Baltimore County, MD
Some older Unidens can't read the tables sent by certain P25 systems, especially when they are on VHF as this system is, for the most part; however they are listed in the database, in case you need them...
Unless using the sites with 800 MHz frequencies, band plans 5, 6, and 7 will be the only ones needed for the 3 plans available in the 796. I don't understand the offset for band plan 5.
Table ID, Base Freq, Spacing, Offset
1-851.00625, 6.25, -45.0
2-762.00625, 6.25, 30.0
3-851.00625, 12.5, -45.0
4-762.00625, 12.5, 30.0
5-150.57500, 2.5, -21.9125
6-149.00000, 2.5, 0
7-161.00000, 12.5, 0
tvengr
Well Known Member
I found that the bandplan will not accept a spacing of 2.5 or 6.25. ARC250 accepts the spacing, but I haven't tried if it will transfer to the scanner.
ORION_NE
Onawa, IA
If it's a P25 system (9600 baud) the scanner will download the band plan. If it's a 3600 baud system using digital voice like south dakota's system then you will need a band plan. I've gotten a 796D to work on the Nebraska SRS without programming a band plan. Once the scanner landed on a control channel the scanner downloaded the info.
KC0CCB
okay good thanks sir
