- Joined
- Dec 19, 2002
- Messages
- 1,017
ALL Frequencies in scanner will be lost !
If you hold 2 9 and scan key while turning on scanner it will load test data.
Five systems are loaded as well as other frequencies.
system 1 says scan test
system 2 says pll lockup test
system 3 says ctcss/dcs test
system 4 says att test
system 5 says disc out adjust also says
adjust voltage enter password.
I did not go beyond this step.
in order to get scanner back to normal had to
press the 2 9 and hold keys to clear all frequencies.
then had to reprogram all frequencies back into scanner.
*** Proceed at your own risk ***
