BCD436HP/BCD536HP: Uniden BCD 436HP Audio is choppy, like its got a priority scan on? Breaks up
powderchaser
SALT LAKE CITY
On my scanner I don; 't think any features are enabled but when I do a zip code search the scanner works, but when it stops on a channel the audio cuts out after a few seconds for a brief moment. Reminds me of old Motorola radios when the scan function was on. I checked the priority scan and it is off. Thes audio is hard to understand since it breaks briefly mid-sentence. Any ideas?
trentbob
W3BUX- Bucks County, PA
And what system are you listening to while this is happening? I noticed that you are All Phase 2 simulcast. Do you think this might have something to do with it? What system are you listening to and what is your hometown?
trentbob
OP... I noticed that it is actually a type ll smartzone system you may be having a problem with and in that case we need to look at a number of things and not just simulcast distortion. Give us more details on exactly the systems you are having a problem with and what exactly you're trying to hear and what your hometown is.
powderchaser
SALT LAKE CITY
I am in Boulder CO listening to Zip code search, high band and combo of P25. Actually it looks like R Mason hit the solution on Close Call. Not sure how I had engaged that accidentally, but when selecting OFF it seems to have taken care of the issue. Thanks. However there is a wildfire in progress here and when Close Call was on (Even thought I did not do it intentionally) it seems the tactical and command channels are coming through. With it off, I am not sure they are programmed into the zip code search. Thanks everyone.
