Uniden BCD 996XT
CT
Has anyone ever done a factory reset on a BCD 996XT
Never needed to.
Here's how:
Turn scanner off.
Press and continue to hold down these 3 buttons....
2,9, and "hold".
While still pressing those 3 buttons, Turn scanner on.
Release buttons and Follow prompts on screen.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You can do that in FreeScan, too (if you mean wipe out all your existing data and start fresh). ...Mike
ofd8001
Louisville, KY
It's not the easiest thing to hold the required buttons down while powering off the scanner. If your fingers aren't "just so" the desired action doesn't occur.
My advice before you try this, is to be sure you really want to wipe the slate clean and start anew. Sometimes it's better trying to figure out what is going on that gets you thinking about a reset.
wtp
Port Charlotte FL
from above...
Here's how:
Turn scanner off.
2,9, and "hold".
number one is turn the scanner off not hit the buttons.
ok if the scanner is off already skip to press and hold.
