UnidenAmatuer
- Joined
- Feb 14, 2023
- Messages
- 3
Hi All,
About 6 months ago, I bought myself a Uniden bcd325p2 because; One, I like to here what happens around my county and Two, I am currently employed at a department. When I first bought it, learning it was a big step because I have never had to program something like this but thankfully to the forums I came across, I was able to set it up without needing any assistance. Now with that said, I live in Waukesha County (Wisconsin) which uses a P25 Phase 1 Trunk System which is 800mhz. I set up my scanner via FreeScan and followed instructions to the T but hardly get any signal if any. I've gone through at least 3 different Antennas in hopes it would change the signal but it does not change a thing. So now, I am reaching out because I feel like I am running out of options and need some experienced help to help me get my scanner to run properly. Is there a common issue that people do that causes this? Is there a certain antenna that would work great with the scanner? Is there a firmware update I am not aware of that I need? Anything and everything would be helpful, even for a trial and error run. If I should post what i have set up on FreeScan, let me know because as far right now, I feel like I am not doing something correctly
Thank You
Thank You
