Uniden BCD325P2 help please
zachful91
Hello, I live in Bloomington Indiana.
Cam someone help me program the p25 so I can listen to police.. not sure how to program a talk group. Uniden BCD325P2
Thank you
tvengr
Well Known Member
Baltimore County, MD
Here is an ARC-XT Monroe County file for the SAFE-T statewide trunked system. Save the attached zipped file to your computer and extract. Open the extracted file with ARC-XT and Upload to Scanner. Quick keys as follows:
Monroe Co IN
SYSTEM QUICK KEYS:
1. SAFE-T Hindustan (Site)
2. SAFE-T Bloomngtn (Site)
3. SAFE-T KnightRdg (Site)
GROUP QUICK KEYS:
1. MonCo Emerg Ops
2. MonCo Fire/EMS
3. MonCo Sheriff
4. Bloomington PD
5. Ellettsville PD
6. IN Univ Police
7. IN State Police
  • Monroe Co IN XT.zip
zachful91
Thank you so much buddy I found out last night I have to add the frequency and the talk groups
CT
Sites are essentially transmitter locations.
You can scan whatever you choose using the quick keys to turn things on and off.
See the list of quick keys above.
zachful91
I live next to the Hindustan tower so I should use that at home. And Bloomington when in town am I getting that right ?
zachful91
Thanks for the help I'm a newbie as you can tell. I'm use to my grandpas pro-2096 just type in a frequency and good to go
tvengr
Well Known Member
You can toggle the 3 sites on and off by pressing 1, 2, and 3 on the keypad. If all 3 sites are off, the system will not scan. You must have at least 1 site enabled to scan. While scanning the system, you can toggle groups on and off by pressing FUNC and then the group quick key number.
tvengr
Well Known Member
The file I provided is only for the trunked system. The frequencies you are speaking of are probably the conventional frequencies for Monroe County. You can create a conventional system and assign quick key 4 to toggle that system on and off. You can also divide conventional frequencies into groups such as Fire, EMS, Sheriff, Police, Public Works, etc. Let me know if you need any help with the conventional system. The system quick key is assigned to the system since a conventional system does not have sites. I can't tell you how active the conventional frequencies are. I am just a little out of range.
zachful91
Is Hindustan for Martinsville? I'm still confused what sites mean and which one I should listen too.. I live by sample road Unionville
tvengr
Well Known Member
A site is a location with the radio equipment (transmitters and receivers). Each site uses different frequencies. There are 3 sites in Monroe County. There is a site in Martinsville in Morgan County, but you wouldn't hear much in Monroe County if you are able to receive it. From the map, it appears that Unionville is about equidistant from Hindustan and Bloomington. Those are the 2 sites you would want to try. If you are able to receive and scan both, it will give you better coverage of the county. If in southern Monroe County, you can enable the Knight Ridge site.
zachful91
So if I can pickup Bloomington sit okay than I don't need to scan Bloomington and Hindustan at the same time ? I'll still pick everything up. ?
