Uniden BCT15 No Sound from Internal Speaker?
RedPenguin
I have a Uniden BCT15 which I had it hooked up to the computer for a while using an audio cable hooked in to the headphones jack.
I can hear audio properly when I hook up headphones now but I can't hear anything out of the internal speaker.
Is there a setting or anything that can be wrong with the settings or does it look like the speaker is dead or something?
pro92b
Mutated Member
This is a known problem with the headphone jack itself, reported mostly for the BCD996T but the jack is the same on the BCT15. Plug the headphone in and wiggle the plug around and unplug. See if the internal speaker starts to work. Try this a few times and if it is still not working you will need to send it to Uniden for repair. Hope your warranty is still in effect.
RedPenguin
Ok
Yeah, I am luckily still under warranty.
I tried wiggling the plug around but it didn't work.
I am going to try it again just to see what happens.
Thanks again for the info.
