UPDATE
ok so this thing is now driving me insane. just like the old antenna, it stopped working. worked out of the box, 1.0 swr on channels 1 through 40, solid calibration, meters not jumping around, talkback works. just like the first antenna.
bring it home and turn on the hf receiver. talkbalk works and i can hear myself.
try it out about three times, didn't change a thing, then it stops working, now the radio is behaving the same as before not working with the new antenna or old antenna. swr jumping all over, can't calibrate, antenna tests pass/fail. radio starts getting solid readings, will key up with silence on the HF receiver tune to same freq, but not modulate. then it started keying up with static.
i'm worried because on the car ride home, i closed the window on the coax. when i took it out, it was bent 90 degrees, and there's a small indentation on it, not enough to cut open the coax. straightened it out and was able to modulate, but only a few times. now it's dead again. i suspect the coax is dead now. unbelievable.
anyway, literally going insane over this. ordered a 195 crimper, some uhf connectors, and a new radio. have some old solid core 195 coax. can't give up on this hobby just yet! will keep you posted.
