HP-2: Uniden repair
nfd540
New jersey
Im looking for a place that repairs HP2 scanner. MY PC DOESNT RECOGNIZE IT YET THE PC RECOGNIZES OTHER SCANNERS. I REFORMATTED THE SD CARD BUT STILL NOT RECOGNIIzing. Other than that it works fine
RandyKuff
Lorain, Ohio
And how did you format the SD card? With an external card reader?
You did set the scanner to Mass Storage mode (When Prompted) when you plugged into your computer right?
fxdscon
¯\_(ツ)_/¯
The scanner won't recognize a new (or newly reformatted) card until you use the "clear user data function" in Sentinel. Put the scanner in "mass storage" mode, then start the clear user data function and check the box that says "display all drives" to select the card that you formatted, then follow the instructions.
RandyKuff
Lorain, Ohio
If he did a format with an external card reader, he can also do the Clear User Data there to if so desired before putting it in the scanner...
donc13
Grand Junction, CO
Simple question, what changed since you were able to last connect to the HP2?
nfd540
New jersey
Idid the clear format also
