uniden software problem with laptop
kevinemery431
Long Beach Ca
When I start up the program on my laptop and I plug in the USB adapter
to the Uniden cable and I press connect to scanner, it gives me an
error message "comunication error! please check scanner remote settings". how do i fix this problem ?
PS i have already tried to update my iogear usb driver but i dont know if i succeeded.
hankv
May I assume that the Uniden Software is the UASD? If so you have to make sure UASD is configured to the right COM Port and connect speed. Also the Scanner should be turned on and connected to the computer before you start the program. :)
PS You didn't say which scanner you have
Dubbin
Findlay Ohio
Look in your device manager and see if there is a little caution sign.
