cg said:A very minor item. When editing a User, an extra line appears with only the numeral 1 on the line. This is between the User:ave .... line and the Label line. (Seen on an EDACS user edit)
Thanks Matt. The log file came through. Those are patches. Unitrunker treats them like temporary talkgroups. Use the [V]iew -> [P]atches display see the patch list shrink and grow.MatteBlack said:Damn, I spoke too soon, I just got a flurry of phantom groups in the past 5 minutes...
Yes, but it's very experimental. If you're feeling adventurous - try running the "Tuner" program to test out the radio (it's buried in the Unitrunker Program Files folder).ogoun said:does unitrunker have support for the AR5000A comms receiver?
Soon I hope. I'm anxious to move on to bigger stuff.Also, how soon will we be able to look at the source code to unitrunker?
This is good and lets everyone know what's up. For back-and-forth conversations I may switch to email.cg said:How would you prefer Unitrunker problems, comments, etc be reported? Here (RR.com), trunker group, email, PM or combination thereof? Whatever is easiest for you.
Expect a delay when doing this. If you get impatient and try to close the program - it will display a "Are you sure ? Yes/No" confirmation dialog. Sometimes this dialog gets placed behind the main program window but you can see it on the taskbar. Dismiss the confirmation dialog by clicking yes/no as appropriate.DaveNF2G said:When I try to Save a new receiver, the program freezes. The only exit is CTRL-ALT-DEL, although Windows XP does not show the program as unresponsive.
Thanks Chris ... I'll check this out.cg said:On two of my machines (one XP and one W95) I am having no problems. On the third, I keep getting the record error. After I went in and changed the sample bits from 16 to 24, then 32 it still would not work. I went back to 16 bits and Unitrunker worked but the error message ended up on 2 lines and it will not clear ("RECORDING" to the right side on line 1 and "ERROR" to the left side of line 2).
Not good. Can you provide a summary of what is different about this computer relative to the other two?cg said:The other problem with the same machine is when I am using Unitrunker on Motorola systems (and MOTO only). The display freezes as soon as the first radio traffic appears. Affiliations work up until this happens. The quality bar freezes as well but I can still use and control the Command / Response Area. The two other computers do not have this problem.
rfmobile said:cg said:Originally Posted by cg
