University Circle 900 Mhz TRS
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
It looks like University Circle might be moving to DMR. The WPVJ676 license is being updated to DMR emissions.
ULS Application - Business, 896-901/935-940 MHz, Trunked - 0008293241 - UNIVERSITY CIRCLE INC - Transaction Log
Existing Motorola Type II system in the DB:
https://www.radioreference.com/apps/db/?sid=2105
Those of you within earshot who might care should consider checking those five 900 mhz frequencies periodically to see if you find a DMR signal on them.
Please submit any updates to:
https://www.radioreference.com/apps/submit/?sid=2105
parma,ohio
Thanks[/QUOTEbeing in parma i will see if i can monitor them from home in DMR
Swipesy
Northern Ohio
That is interesting since University Pd just moved to GCRCN, TG 56731 a few months ago. They were on a horrible 900 band FM prior to the switch to GCRCN.
mtindor
OH/WV DB Admin
This looks to be a two-site simulcast DMR system for University Circle Inc. They just filed to add additional frequencies. So If there is anyone up in University Circle area able to use DSDPlus to check around on 900 mhz, please do so and report what you find.
WPVJ676 - University Circle Inc (DMR Trunked License)
Cleveland OH (Cuyahoga)
2242 Circle Dr
41-30-15.2 N, 081-36-14.5 W
935.275
935.525
935.7875
936.15
936.45
936.675
937.25
937.725
938.2375
2065 Adlebert Rd
41-30-19.5 N, 081-36-22.2 W
935.275
935.525
935.7875
936.15
936.45
936.675
937.25
937.725
938.2375
mtindor
OH/WV DB Admin
Also -- a CWRU (Case Western University) 900 Mhz DMR trunked license update - same location
935.2125
935.55
936.1375
936.3625
If you are up around University Circle, please consider trying to sleuth out these two systems.
FCC notification suggesting at least partial progress (936.3625 and 936.55) - ULS Application - 0009305271 - Case Western Reserve University
TV88KEYS
Cleveland Ohio
I spent some time in University Circle monitoring CWRU DMR system and UC DMR system yesterday.
936.6750
937.2500
937.7250
938.2375
These were active on the UC system
Talkgroups
1305,1323,1375,1341,1354,1357,1342,1306,1310,1317,1345 and 7 were monitored..They all seemed to be maintenance related from what I heard.
935.2125
935.5500
936.1375
These were active on the CWRU system
Talkgroups
8231,8702,9002,1456,9001,1131,2222,2255,2208,8905,and 8151 were monitored..These were mostly maintenance related with a few handling parking garages and deliveries..The reception in University Circle was excellent..About one or two miles outside of that I got no reception..I was using my WS1080 with RS 800 MHZ antenna...I will be going back in the near future to try and separate the talk groups and determine exactly how its setup.
wa8pyr
Technischer Guru
Staff member
Lead Database Admin
Ohio
936.6750
937.2500
937.7250
938.2375
Talkgroups
935.2125
935.5500
936.1375
Talkgroups
Could you go ahead and submit this under the Cuyahoga County tab so we ca get it into the database?
mtindor
OH/WV DB Admin
Nice start. Nice to know it is indeed active. Based upon @TV88KEYS remarks, one is going to have to be very close to monitor either of these.
We are going to need more details -- System Type (Cap+, Con+, DTIII, etc), LCNs, and Color Codes before anything can be added to the DB.
Mike
