Did you install the driver for your programming cable? If the cable has a mono adapter on the end, remove it. The PRO-164 requires a tip/ring/sleeve stereo plug. Make sure you are plugged into the PC/IF jack and not the headphone jack. What is your city, county, and state, and which systems and agencies are you trying to monitor?
