USB Bluetooth dongle?
donc13
Grand Junction, CO
Will the SDS200 accept and use a standard USB Bluetooth dongle?
If not, will/does Uniden have any plans to add that capability to the SDS200 via the USB A port on the front that supports the A2DP profile and optionally mutes the speaker when paired with a headphone?
That would solve my problem of using an earphone via the front audio port with wired headphones.
Yes, I know you can buy an audio bluetooth adapter that plugs into the audio out port, in fact, I have one... works well... except the adapter has to be recharged about once a day, whereas a USB dongle doesn't.
Don
RandyKuff
Lorain, Ohio
On the 200 you can plug your BT adapter in the headphone jack and a short charging cable to the front
full size USB A port to keep it powered Indefinitely....
Athough you will probably need a ground loop isolater though going that route...
donc13
Grand Junction, CO
Thanks, unfortunately the Creative BT adapter doesn't charge via USB but via a dedicated 110v charger (same with the headphones).
Don
RandyKuff
Lorain, Ohio
What type of plug is on it and what is the output voltage of the AC adapter...
A picture would be great if you can post one...
donc13
Grand Junction, CO
Don
So shall you ask, so shall you be given:
Plug... Audio plug, charge socket... Cylindrical pin
Photos..
So shall you ask, so shall it be done:
RandyKuff
Lorain, Ohio
But whats the output voltage from the AC adapter 5Vdc by chance...
If 5Vdc you can do it... With an adapter cable...
kruser
Well Known Member
W St Louis Cnty, MO
