I ran the trouble shooter.
It States the driver is not installed. But when I try to use the update I get "...Service installation section in this INF is invalid.
The COM port gives the following under the properties tab:
The drivers for this device are not installed. (Code 28)
A service installation section in this INF is invalid.
To find a driver for this device, click Update Driver.
It is a endless loop, no matter how I go about it, I always have the same results:
I un-install clean everything up, and try again. I have used the link you supplied, the files with the CD, The FTDI web site and US Converter's web site files.
Same results. But only on the AMD processor. The laptop with the Intel Pentium works.
The laptop: HP 2000-2C29WM Notebook PC, Product: D1E81UA, AMD E-21800 APU with Radeon HD Graphics 1.70 GHZ. I went thru making sure all was updated, but same results:
Also when the device is first connected, the SERIAL CONVERTOR is installed under the USB Controller.
The USB SERIAL PORT appears under the PORT table with exclamation mark with no driver installed message. When I try to update it, that is when the final result is A service installation section in this INF is invalid.
Thank you,
Mike
