Hello,
i have two MTP850 Fug, which i want to use as modem transfering AT commands. Unfortunately i can use them only in the Direct Modem.
In the TETRA Terminals Product Information Manual is given:
1. Connect the data cable to the terminal’s data port.
2. Connect the other end of the data cable to the computer.
3. Power up the terminal
4. From the terminal’s menu, select Setup > Data Setup > Voice and Data (or Data) mode option
The problem is that i can't select Setup>Data Setup > Voice and Data while the device using the Direct Mode: an error message : Service is limited appears.
Does anyone have experince using the devices as modems in the Direct Mode?
Roman
Roman
