prcguy
- Joined
- Jun 30, 2006
- Messages
- 17,924
- Reaction score
- 13,473
If the signals arrive 180deg out of phase at the inputs of the divider, they will cancel out when measured at the output of the divider no matter what the isolation is between ports. If you have 4 identical antennas and the exact same electrical lengths of coax AND a good quality combiner, the results can be predicted. Using 4 different antennas will have signals arriving out of phase at some frequencies. The best way to prevent this is to use a diplexer/triplexer or band pass filters for each specific antenna, If you use filters and a 4-way combiner you'll have at least 6dB loss from the combiner. You can combine filters directly using "T" connectors or 3, 4 or 5-way "star" connectors with no loss and you would basically have a diplexer/triplexer/quadplexer/etc when your done.
prcguy
prcguy
Hello zz0468:
Snip...
The four antennas will have equal lengths of coax feeding the four port combiner. And will add up signals in phase more than not be in phase. Even when a signal arrives exactly out of phase for two antennas the side antennas will only be 1/4 wavelength out of phase. And the Combiner will have a 20 dB or more isolation factor so if a signal does make it in 180 degree's which is out of phase the combiner isolation of 20 dB or more will only allow less that 1 dB to be subtracted from the original signal level. Most acceptable.
Jay in the Mojave
