caterpillar16
I would like to use a Telemetry Cable PMKN4040A on an XPR7550 radio, and then run a wire (and ground) to a contact switch, so that, when programmed correctly, I can use a programmed button on another radio to signal the XPR7550 to send a telemetry signal to open the door. I don’t want to use it to close the door. I’ve seen some examples online, but they’re all related to an example where a water tank gets filled. Has someone done this before that can walk me through the correct configuration in CPS, and also tell me what protective measures I should install in the circuit to prevent damage to the radio?
