Using the Raspberry Pi and a RTL2832U Stick for SDR over Ethernet
KS4JU
From what I read and my experience, it seems that a powered hub won't correct the issue.
Pape
Where are you getting the connection issue? From the SDR Sharp side? What errors to you see?
Pape
Quebec
when I connect using the sdr#, this is why I want to know if there is a other client out there I can test with so I can cut the apple in 1/2
KS4JU
Does SDR Sharp connect then crash or does it run for awhile and stop?
Just a couple of thoughts.
Since this is all being done over TCP, it might be a network problem. If SDR Sharp loses the data stream it will potentially hang up.
After many hours of fooling with the Pi, I found that it can be a bit cantankerous. When I first started experimenting with it, I was having all kind of weird problems. It turned out it wasn't happy with my SD card. Putting in a new one fixed it right up. So, you never know what might be going on.
As far as the turbo mode is concerned, it only kicks on when the Pi deems necessary. There is a little indicator on the lower right corner you can mouse over to see what frequency it is running at.
The only other program that I am aware of that can use the RTL sticks over TCP is SDR-J
However, is not as easy to work with as SDR Sharp in my opinion.
Bellingham Washington
this is weird, can you add a usb power hub and connect the rlt to it ?
Some devices require more power than what the PI usb can deliver, don't think this is the case but nothing to lose neither
Well I'll be, it works with a powered USB hub.:lol:
You know overall I am beginning to think the R-PI is not worth it. Sure it's cheap $35 for the Pi, then $20 for a good power supply and USB cable, $20 for a big SD card, now $35 for a powered USB hub and power supply.
That is slightly more than half the cost I have in the mini-ITX system I built for my streaming server for maybe less than 1/4 of the performance.:(
Pape
Quebec
interesting, will need to try this and see if it fix my conecting issue
Chezzdevil
Rodès, France
Good morning ,
I'm actually going for the inverse setup; I want to plugin the dongle in my PC, run tcp_ip and decode on my Raspberry (and also on my tablet) using gHDSDR, but none of them want to connect to the SDR-server over wifi to my PC, guess that is more a networkconfiguration error than anything else ?
Thanks for you all your insight and constructive remarks, love the forum !
Serge near Perpignan, France
Pape
Quebec
can you verify if your firewall is enabled, can be found under control panel -> windows Firewall.
If disabling the firewall (all 3 of them) fix your issues I recommend you re enable them and perform a port opening instead.
Chezzdevil
Rodès, France
Hi , and thanks for the fast replies :), I don't think it's a firewall issue;
When running rtl_tcp console in a cmd prompt (from the PC side(win 7)) - when i open a browser on the tablet pointing to 192.168.0.2:1234 the console starts counting, exactly as any other client on an other device.when I do that. It seems there is a prob with the glSDR running on the client (tablet)-side, the polling from the Android yields nothing... although the menu SERVER IP's function well (the nacap.ca server works great in master mode), polling my local ip gives rx0 unknown, host unresolved ??
Thanks for helping me out, I see some other users have no prob running on ICS A500 (have glSDR version 28, tried with 25 too) ?
Pape
Quebec
Got time to try the usb power hub on the PI and well it solved my crashing issue so far, knock on wood.
Will need to try my usb wireless dongle as when it come under load I lost wireless connection....
Burritoe
Amity, Oregon
I've picked up a powered usb hub tonight and it fixed my problems. Now when I start rtl_tcp I get
Found 2 device(s).
Found Rafael Micro R820T tuner
Using ezcap USB 2.0 DVB-T/DAB/FM dongle
Exact sample rate is: 1000000.026491 Hz
Tuned to 161000000 Hz.
listening...
Use the device argument 'rtl_tcp=192.168.1.215:1234' in OsmoSDR (gr-osmosdr) source
to receive samples in GRC and control rtl_tcp parameters (frequency, gain, ...).
I am setting one dongle up for vhf and one for hf using the upconverter.
So far so good. The two seem to work fine, just not at the same time. I lowered the sample rates of each and tried to run two instances of sdrsharp but they choked out, and I am not really going try to fix that problem.
I start two instances of rtl_tcp, each with different ports, and using the -d option to select which device. In my dongle 0 or 1. Then in sdrsharp I just change the port number to select which dongle to listen to.
AIS_GOD
Dont know if this was adressed but i solved alot of the RPi errors by lowering the sample rate under configuration. Is there a way to have the rtl_tcp to auto-start/connect and tunnel out of network? I want to put these up in remote locations where i wont be able to tunnel into the network from my server and need the client to tunnel out.
Your_account
Banned
.AT
I got an raspberry pi 2 for 80€.... and i want use it for sdr over network.
Where is a Ready to use Image?
