Vertex Question (Help)
countyman954
Hello everyone,
I need help with something. I have a Vertex P829-DO-5 radio. (P25 capable). I'll try to put this in an nutshell...I have several (all digital P25) frequencies programmed into the radio with CORRECT NAC code as well. The frequencies used to work up until a year ago, transmit and receive. (The radio has just been sitting since). All frequencies will no longer pick up or transmit. I have tried playing around with programming software and programming different options in hope of it working again, but to no luck. The current firmware version is 7.18.
I'm told I need a Conventional Personality (Signaling Digital Modulator Type) of "CQPSK"? I don't know what that is or where to input this into the programming software? I also need the modulator type set to "C4FM" as well for several frequencies to TX.
Again, I have all the frequencies correct as well as NAC codes. Is anyone familiar with this radio and its software? If so, what do I need to do? It used to work fine.
