I'm having an interesting problem.
I have installed an Icom IC-208h in my wifes vehicle (1998 Dodge Durango). Power comes directly from the battery and thru the firewall using 10 gauge wire, properly fused, etc... The ground is under the hood and using the same grounding point as the ABS Computer (among other things) and was testing .4 ohm from this point to the negative side of the battery.
Antenna is a Mag Mount quarter wave VHF until I get a new NMO mount and the vehicle thaws enough to drill the roof. The antenna is placed on flat roof, forward of the luggage rack area on the roof. I dont have enough coax to relocate the antenna anywhere else on the roof.
When I key up on High Power (55 watts) VHF, it was knocking the FM radio out until I un-keyed. It is also knocking out the power to my cig lighter / Powerpoint and my GPS plugged into the outlets. (The LED in the cord goes out).
But when I key up on 50Watts UHF, (similar power drain) nothing like this happens.
I'm somewhat confused, and I understand that it could be the mag mount (hasnt happened to any other cars I've used this mag mount on), but I want to know for sure before I drill a hole in my wifes vehicle.
Anyone have any ideas?
EDIT:
I just realized that I havent hooked up a voltmeter while keying down to see if there is power fluctuations. I might try that tomorrow if I get time.
Anyone have any other ideas?
EDIT:
