Voice files for Minitor VI not accepted by programming software
human8472
I attempting to create voice files for my Minitor VI using the free software program Balabolka. This is the same program I have used in generating WAV files for me APX 6000 radio. I have generated the files using the following parameters ..
1) 8 kHz
2) 16 bit
3) Mono
When I attempt to import these into the Minitor VI Programming software I get the following error (screen capture attached).
I have also attached a sample WAV file I have created. I had to upload it as a ZIP file as direct uploads of WAV files do not seem to be supported.
Any idea why this might be happening? I have confirmed that I am setting the parameters of the WAV files correctly. I am stumped.
  • Sample.zip
Asunakiyori
Lurker
Hiding in a Shed somewhere
Ive had issue between radios using multiple programs. Only one worked for my XPR, Apx, and Harris, if i use anything else it fails hard. I wonder if there is a setting on your program thats missing? is it a PCM float?
human8472
Sorry, I am not familiar with a PCM float. What is that?
human8472
Thank you all for the help. I ended up reinstalling the Programming Software from this link and it solved my issue. Voice announce works and I can upload WAV files without issue.
