Voice storage on conventional
TxScanner
How do I enable voice storage on conventional frequencies? Thanks
CanesFan95
Analog already is interoperable.
FL
Probably by going into D6, clicking into a knob position, and choosing All Voice here:
TxScanner
Thanks, I did that in the different Zzone and knob positions, but if I have the group of frequencies in a normal scan, it only gives me the option of adding ID match
Multi Channel Scan Voice Storage
  • Definition
    To select how to record the voice message when receiving voice calls with/without protocol signaling IDs.
  • Options
    1. Off: Do not record the voice calls when receiving the voice call regardless of ID.
    2. ID Match (Default): Only record the voice calls when receiving voice calls with matched IDs.
    3. All Voice: Record all voice calls regardless of IDs.(Only available in CSQ monitor mode)
  • Note
    1. When Receiving Mode is Selective Call, the voice message will not be recorded in CSQ channel.
    2. All Voice option only available in Conventional Monitor Mode , not support in trunking
