I noticed the SDS200 has volume adjustments (-3, -2, -1, 0, +1, +2, +3) available for each channel or talkgroup. Or, you can globally set this in the software, where all can be set at once. My understanding of the feature is that it gives us the ability to either increase or decrease the volume on each channel or TG and “balance the audio output, eliminating the need to continuously increase or decrease the volume of weaker or stronger audio signals. I gave the global setting a try after I had turned the volume down to a position on the knob where audio stopped being passed to the speaker and noticed I still had room to further reduce the volume before the on/off function was reached. Thinking if I globally set the volume to +3 I could gain additional volume control, I tried it. And it worked for the trunked systems but not the conventional systems. It’s just an observation on my part but thought it worthy of mention. Has anyone got some insight on this? I do not consider this a ”bug report”... it’s just the nature of the beast... most probably caused by the software defined radio.
