BCD325P2/BCD996P2: VTAC Frequencies
KW4PI
Seneca, SC
Can't get the VTAC frequencies into my scanners (RS Pro82, Uniden BCD996P2). Is there some voodoo I need to do? Thanks.
Whiskey3JMC
Just another lowly hobbyist
Philly burbs 🇺🇸
Why not give us some info on what happens when you try...Errors encountered? Are you programming by hand or using an app? Frequencies are VHF conventional so no "voodoo" should be needed
155.955WQGC429M156.7 PLSCVTAC1SC VTAC 1 StatewideFMNMulti-Tac
155.160WQGV825M156.7 PLSCVTAC2SC VTAC 2 StatewideFMNMulti-Tac
155.535KB36284M156.7 PLSCVTAC3SC VTAC 3 Chester/Lancaster/Union/YorkFMNMulti-Tac
155.550KB36284M156.7 PLSCVTAC4SC VTAC 4 Clarendon/Kershaw/Lee/SumterFMNMulti-Tac
155.010KB36284M156.7 PLSCVTAC5SC VTAC 5 Georgetown/Horry/WilliamsburgFMNMulti-Tac
155.070WQGC429M156.7 PLSCVTAC6SC VTAC 6 Berkeley/Charleston/DorchesterFMNMulti-Tac
KW4PI
Seneca, SC
I was trying to program in the national VTAC frequencies...which have four digits to the right of the decimal point.
Example V-TAC 1 - 151.1375, V-TAC 2 154.4525. It's the .0025 steps that seem to be the problem.
I had not known about the SCVTAC freqs at all. Did you find them in RR?
wtp
Port Charlotte FL
have you found the nationwide one ?
database
browse United States
right side menu, click it.
What is your frequency step set to?
Should be 7.5KHz.
hill
Middle River, MD
PRO-82 is too old and was made before the narrowbanding was a thing, so won't be able to enter the exact frequency, but still be able to receive with the rounded off one.
Audio will quieter with receiving a narrowband signal on wide band setting, but still allow you to listen. Also may get signals from other close frequencies.
996P2 should be alright being a newer model with narrownband.
