MTS2000des
5B2_BEE00 Czar
I will switch out the LMR400 coax. I am running a 5.26MHz split.
Depending on the model of the duplexer inside, that may be cutting it close. Most flatpacks on VHF require a 6-10MHZ minimum to obtain the rated TX/RX isolation. If it gets 80db I'd be surprised. A good set of duplexers for VHF can cost more than the VXR7000.
Having cut my teeth on VXR7000s on VHF, they are GREAT radios IF you have a good duplexer/filter setup, feedline and decent antenna. As far as your fan running 24/7, the VXR7000U we have as a spare does not do that. It's thermally activated.
People go in debt and spend tens of thousands of dollars to try and obtain an education so they can work in their respective field.
Yep, and sometimes they spend thousands more learning "the hard way", but those lessons usually are not repeated.
I don't want to just burn money but the cost of this education is much more appealing than just paying someone to come out and do it for me.
I get that you want to learn. I just had this very conversation with someone on my ham repeater yesterday who is eager to put a P25 backyard repeater. He, like you, has a thirst for knowledge which is awesome. We need more people such as yourself who actually want to LEARN the why's and how's of RF instead of just writing a check or changing parts.
That being said, there is quite a bit of a black art to making repeaters work, and the ugly truth is that expensive test equipment like a service monitor/tracking generator is really necessary (along with the knowledge to use it!) to do the job RIGHT.
You're on the right path. Hopefully you can find someone in the radio community in your neck of the woods who can come out with his service monitor and show you how and let you drive so you can get the hang of it. It's really not that hard but you do need the car to take round the track!
Good move on dumping the LMR400, it's great cable for base stations, but not repeater (duplex) operation. LDF-50 is a good choice.
