Walkie Talkie Question
dsemergency
Pa.
I'm not sure if this is the place for this question but here it goes.
Can any one suggest a Motorola Talk About radio that would be good for hunting & using in the outdoors.
I don't know what the difference is between the FRS/GMRS models & ones that are not.
Macomb, Michigan
Heres what FRS is Family Radio Service - The RadioReference Wiki
This is what GMRS is General Mobile Radio Service - The RadioReference Wiki
BestBuy has some 2 way radios and so does radio shack 2 way radios - BestBuy
Walkie Talkies & 2-Way Radios : Radios | RadioShack.com
gewecke
Banned
Illinois
Motorola T7200 if you can find one. :)
n9zas
jaspence
Michigan
FRS radio
If you are going to be wearing gloves, get a larger radio rather than one of the smaller models. Rechargeable batteries are great, but for camping a model that can also use AA (avoid AAA) batteries is a good idea. If you must use rechargeable batteries, then an extra battery pack for each radio is a must. These suggestions are based on over twenty years using FRS and amateur walkie talkies.
N0BDW
Livingston Co., NY
I use MURS on HT1000s. The radios are tough as nails (can pound nails with them and keep on talkin') and MURS is VHF. I tend to like the properties of VHF better than UHF for my purposes. Will probably run you ~$200 - $250 for a set if you find a good deal on eBay, so they aren't cheap. The advantage is if you ever want to get into amateur radio, or monitor other things on VHF, you can.
If you are lucky enough to find one, I'd say the HT1000's bigger brother, the JT1000 is the best radio for outdoor use. Especially if you get the FPP intrinsically safe one. These tend to be at least twice as expensive though.
One thing to be aware of though is these things are built like TANKS. And like tanks, they are HEAVY for a two-way radio.
They are dead simple to use though. Turn one knob to turn them on/adjust the volume, turn the other to set them to the same channel. Push the big button on the side to talk. Pretty idiot proof.
Just depends on how serious your communications needs are. The HT1000/JT1000 used to be the de facto standard for serious commercial/public safety communications.
gewecke
Banned
Illinois
You bet. the Motorola T7200 was suggested for that reason also. Digital pl is the ONLY thing it won't do. :)
n9zas
