Waterbury pd/fd on sds100
ckohanowski
I have reprogrammed my sds100 a few times trying to receive waterbury pd/fd. I tried sentinel and using rr database. I still can't receive anything. I used to a month or so ago on both my 396 and hp2 but now nothing. They are only about 15 miles away from me. Anybody else have issues?
Whiskey3JMC
LMR Explorer
Philly burbs 🇺🇸
Are you monitoring the system linked below? Are you getting any bars of signal from the control channel at all? If so the first step I would take it to make sure all applicable service types (reference "tag" column) are turned on otherwise the scanner will omit those talkgroups
n1chu
Farmington, Connecticut
I also did the “automatic” RR download with no problems… last time I heard both PD & FD was about two weeks ago when I was in the area-no problems. I run the SDS200.
tvengr
Well Known Member
Baltimore County, MD
If you attach your 396, HP2, and SDS100 files, I will check them for problems. I have both ARC396 and FreeSCAN for your 396. Check the squelch level on your scanners. For the SDS100 it should be 2.
W1KNE
Owner ScanNewEngland
New England
You're 15 miles outside of Waterbury? You don't mention which town. My last time down around there, the coverage is pretty well city centric and you don't get it much further out. The system is optimized for in city coverage and if you're in, say, Meriden (On the west side of Hanging Hills) it comes in choppy.
tvengr
Well Known Member
I know exactly what has happened. The control channel frequency recently changed to 852.1125 which is not listed as control channel capable in the Radio Reference database. To be safe, enter all of the frequencies into the scanners. The site shows 6 control channel capable frequencies. There should be only a maximum of 4, one primary and up to 3 alternates. This could possibly be a Harris system in which any frequency can be used for the control channel.
scanningct
I can confirm the system is coming in OK on my SDS100. Just heard PD/FD/Public Works. The signal has always been a little weak for me here in Newtown. Need to be in a specific area of the house to receive. You can also try using the 'Analyze' feature and walkaround your area to see if it picks up the system information. It will also show signal strength.
pro106import
Milford, Ct. perched high above Long Island Sound
Are you sure about the site NAC? The RR database shows 097.
Waterbury
Site: WaterburyBack to system
Site Number:Decimal: 001 / Hex: 1
RFSS:1
Description:Waterbury
Unique DB ID:21740
NAC:097
County Location:New Haven
Neighbors:N/A
Modulation:CQPSK
Notes:N/A
FCC Callsigns:WPLU572
yes sorry I forgot the G5 shows the NAC in decimal form. So yes, 097 is correct for the SDS
ckohanowski
Thanks for the replies everyone. I'm in oxford and always received wtby with no prob. I am looking in configuration and see I have nac # 100, 200, 300. I will change and see if it works. Control channels include 852.1125
tvengr
Well Known Member
It seems strange that all 3 scanners stopped working at once. There was another member that found the scanners started working again when 852.1125 was added. This was a recent change. To be safe, make sure all 10 of the frequencies are in the site.
1 (1) 001 (1) Waterbury 851.1875c 851.3375 851.5875c 851.8375c 851.900c 852.1125 852.175c 852.900
853.650c 853.9875
W1KNE
New England
852.1125 is now in the DB as a control channel capable frequency. 851.3375 is as well (which is one from my records). If this is a Harris P25 system, I'll just flag the remainder, as any can be on a Harris system.
tvengr
Well Known Member
Thank you! I suspect that it may be a Harris system also. I found it unusual that there were 6 control channel capable frequencies listed in the RR database when there should be a primary and a maximum of 3 alternates unless it is a Harris system.
55engine
Hartford County area
If I’m not mistaken, I think Waterberry at one time had Johnson and then I think they moved over to Harris I don’t remember
nhfdcadet
GCT-1
New Hartford, Ct
It's an atlas system
