Just asking to try to see what all have in common not laying blame trying to see what is or is not common.
Did you have the SDS100 hooked up to an outside antenna?
Do you have a preamp in your antenna system?
Do you have your antenna system grounded?
Mine has not failed but I am hooked up to a grounded ST2 split two ways going to 2 Stridsberg MCA208M multicouplers for my home setup and a larson triband to a Stridsberg MCA204M in my car.
I was mostly using an RH77 BNC or Watson 801 BNC. I do have a setup similar to yours, with an added cable TV preamp at my ST-2 antenna and only one 8 port Stridesberg active multicoupler. Antenna system is grounded.
