what can i here
NCVFD1
Niagara Falls
Iive in niagara falls ny : i have a pro433 & pro 163 i would like to here some fire/police can someone help in any way thank you mike
NCVFD1
Niagara Falls
1st Canadian Place HELP
I have the ARC-433 and ARC-300 do the status bit on or off // end code on or off // control channel on which plan 1-4 thankyou
motomeso
Ontario
Buffalo Police and Fire should be a go for you. Every other PD call is for shots fire so it should keep you entertained for a while. Search the database here for Erie CNTY in NY.
mciupa
Canadian DB Admin
Moderator
I'm here a lot
I have the ARC-433 and ARC-300 do the status bit on or off // end code on or off // control channel on which plan 1-4 thank you
Status bit OFF
End Code ON
What are the variations of band plan 1 to 4 :confused:
Use primary and alternate control channels
mciupa
Canadian DB Admin
Moderator
I'm here a lot
FYI...
The glossary in our wiki has a nice explanation of control channel only mode - go down to the bottom where it says 'Uniden Plan Information'. Here's the link (always in blue)
Control Channel Only - The RadioReference Wiki
73 Mike
Thanks Mike :)
It some times pays for one to read more than the top of a page. :roll:
