I was trying to wire a Hirose quick disconnect for my XTS2500 after soldering the pins in the wires I put it on the radio to test it of course it failed it and I noticed that two wires were cross the input for the Mike Mike and also the speaker input didn’t think much of it took off soldered it went back to the radio and discovered the radio didn’t work with the internal speaker? I couldn’t figure out why I checked all my settings and found nothing wrong. I was hooked up to speaker mic and all worked. Normally all the system beeps and sounds worked, and all rc work as as they should
So that radio doesn’t work with the internal microphone, but it works fine with audio when I hook up the speaker micA also, is there a service center nearby Dallas area I need a place to get it fixed and I need to get it aligned. Thank you.
