Arizona Fire Departments and Forest Fire Crews
This feed reported online at: 2022-07-28 10:26:11 CDT
there was a question that my feed did not match what the new stream is called.
the new stream is called Maricopa County Public Safety.
the reason was when the power came back on my scanner loaded everything back on including airport frequencies. During fire season airport frequencies are used a lot for air to ground and air to air talk over the fires. so when the radio rebooted it put the scanner list back in the stream, I removed these frequencies so it will not show again until next fire season when I will reprogram them back into the scanner. Kind of rude for this to come from you folks instead of the person that sent it to you.
All the person had to do was let me know. I do run the Arizona scanner enthusiasts facebook group , He could have let me know there.
User tillman42 (xxxxx@xxxx.xxx) has reported a problem with your feed. Feed: Maricopa County Public Safety Problem: Audio Does Not Match Description Details: I only heard one call for Mesa Fire and then All I get is Airport frequencies on this feed.
