Thanks WZ1! I would have the radio programmed for me before it get's shipped and was just wondering about the reprogramming for the long run. When you said that scanning an EDACS system is not for the casual listener, you meant that programming the radio can be very complex right? If it's already programmed before it gets to me and all I plan on doing is listening I shouldn't have to worry about anything right? By the way, all TX will be disabled so that would not be an issue.
Sounds like you're new at this, so can I suggest you figure some things out before the
radio gets shipped?
Someone correct me if I'm wrong; but doesn't an EDACS radio programmed as a system
require a system key? People authorized shouldn't be giving these out to just anybody,
and if somebody's offering to use one who shouldn't have it, I wouldn't go there
(and I don't want to know about it).
Then it's reduced to scanning system frequencies manually; not sure how well
that would work in this case.
Second point, do you know which talkgroups to get programmed (if you have one
chance, without having to send it back and likely pay). The RR Database has some
specifc/dated info, but there's a whole lot of digital TGs not listed (dozen or two). I don't know
what they all are, but anyone who runs ETRUNK or UniTrunker can see them.
I suspect people who know keep this fairly quiet. Up to now, ability to monitor
clear Provoice has been fairly limited, but is now opening up with DSD software,
although getting a trunked setup is not a pushover.
As for TX disabled, great, hope it is done correctly. Possible consequence if it's
not, are radio interefering with the system, and likely getting shut down over the
air ("bricked") which will render it as a bookend.
Last; EDACS is on the chopping block. Harris (or should I say, Harris/Tyco/Macom/
Com-Net/Ericsson-GE) (did I miss any?
) will support what's there for now, but eventually
Ottawa has to switch to something else (P25 is one rumoured); system is now ~15 years old.
Dave
