What Is TRACON?
kb5udf
Louisiana
Half of it
Being your are in Canton, you will probably hear at least half of the Airplanes calling Approach for Cleveland, given your distance, but it is most unlikely you'd hear the airport side of the call, given your distance.
For most common scanner setups even with an outside antenna, unless you are in a very high place, you probably won't hear an airport 30 miles away (the tower itself).
